ผู้เขียน หัวข้อ: Patek Philippe CALATRAVA replica  (อ่าน 184 ครั้ง)
ออฟไลน์ yanyek
  • กระทู้: 10
« เมื่อ: 09พ.ค.2025, 14:32:42 »
New Patek Philippe Calatrava 8 Day 5328G
The practical and simple Calatrava is equipped with a powerful fresh 8-day movement.
Patek Philippe introduces a fresh powerful manual-winding movement for that equally new Calatrava 8 Day Ref. 5328G. Becasue it is name suggests, this new double-barrel movement offers a power reserve all the way to 192 hours (or 6 days). Although the watch will be officially called the Calatrava, that complements the more casual artistic of the Travel Time 5326 watch and adheres to just one of Patek Philippe's 2025 goals: to provide practical, very intuitive complications as well as easy everyday maintenance.
Given that 1932, the Patek Philippe Calatrava collection has been thought to be the epitome of ultra-thin costume watches. Although some classic types are still available, the collection started out a new path in 2015 with the introduction of the unexpected Calatrava Travel Time 5524. In 2022, Patek Philippe presents the Calatrava Twelve-monthly Calendar Travel Time 5326, an extremely practical travel enjoy. With its textured dial in addition to guilloché finish on the circumstance, this new model is a excellent sister to the Annual Calendar.
Jacob and Co. epic x replica
replica Patek Philippe Calatrava
swiss cheap Watches
The 41 mm white gold case is 15. 52 mm thick as well as features a hobnail guilloché routine on the case sides. This specific historic pattern, featuring smaller than average shiny pyramids, adorned typically the bezel of the 1934 96D model and the 1985 Calatrava 3919 model.
The blue dial characteristics two trendy details: any grained matte surface and also a gradient effect that steadily transitions to a more soaked, almost black tone on the outer edge. The night out display is located in an aperture in the date subdial and is also indicated by a hand with 6 o'clock; the day and day displays bounce instantly at midnight. A reduced hand on the subdial shows the small seconds. In contrast to often the date and day surfaces is the power reserve indicator on noon. The dial attributes white gold Arabic numerals having luminescent coating, as the actual vintage-style syringe-style white gold hour or so and minute hands.
The new manual-winding activity - calibre 31-505 8J PS IRM CI N - has two series-connected barrels with a power reserve provides 8 days. The first lens barrel is equipped with a sliding equilibrium spring; when winding, the two barrels store energy concurrently. As the main barrel little by little weakens, the auxiliary gun barrel recharges it by shifting energy according to the principle regarding communicating vessels. The power hold indicator provides a smooth torque of up to 8 days, while using red zone coinciding together with the ninth day, reminding one to wind the watch.
replica Audemars Piguet Watches
replica Breitling Endurance Pro Watches
luxury Replica watches
The classic construction of the mobility is further enhanced from the 4Hz Pulsomax escapement throughout Silinvar (silicon). Most of the movement's structure is visible through the blue crystal caseback, hidden beneath the elegant bridges decorated along with Geneva waves.
Technical specifications - Patek Philippe CALATRAVA 8 DAY 5328G
Case: 41 mm diameter x 10. fifty-two mm thickness - 18 carat white gold, polished, guilloché hobnail pattern on case attributes - Sapphire crystal and also back - 30m water-proof
Dial: Blue uneven gradient dial - Utilized white gold Arabic numerals together with luminescent coating - White gold or platinum syringe-style hour and second hands with luminescent finish - Day display with aperture, date hand in subdial at 6 o’clock -- Small seconds in day/date subdial - Power reserve signal at noon
Movements: 31-505 8J PS IRM CI J - Manual winding - 32 milimeter x 5. 05 millimeters - 256 components : 28, 800 vph rapid 192 hours or main days power reserve - Several hours, minutes, seconds, instant time and day display, reserve of power indicator
Strap: Deep blue textile calfskin - White gold or platinum triple folding clasp instructions Comes with a grained taupe calfskin strap
Reference number: 5328G
4 ตอบ
2716 อ่าน
กระทู้ล่าสุด 05ธ.ค.2018, 15:16:57
โดย bymanshop
409 อ่าน
กระทู้ล่าสุด 11ก.ย.2025, 16:10:18
โดย yanyek
75 อ่าน
กระทู้ล่าสุด 26ธ.ค.2025, 11:41:25
โดย yanyek
67 อ่าน
กระทู้ล่าสุด 05มี.ค.2026, 14:00:04
โดย yanyek
71 อ่าน
กระทู้ล่าสุด 02ก.ค.2026, 19:03:00
โดย yanyek
