สเปค เพาเวอร์ครับ
Amplifier Section
Power Ad Hoc : 330W at 4 Ohm from 20Hz-200Hz with < 1% THD1
Speaker Impedance : 2-8 Ohm stereo 4-8 Ohms mono
Max power output : 1100W max power
Power
Power Requirements : 12V DC Car Battery (Negative Ground)
Current Drain : At rated output: 60A (at 2 Ohms) Remote Input: 1 mA
Output Power : Maximum Output: 600W (at 4 Ohms); 1100Wx1 (at 2 Ohms)
Rated Output : 330W RMS (20 Hz - 200 Hz, 1.0% THD + N, at 4 Ohms, 14.4V)1 600W RMS (100 Hz, 1.0% THD + N, at 2 Ohms, 14.4V)
Input Voltage : 10.5-16V Power Supply Voltage
Internal Power Supply : Class D Technology Pulse Power Supply
Audio
Harmonic Distortion : 0.1% or less (50Hz)
Input Level : 0.3-6.0V (RCA pin jacks) 6.5-16.0V (High Level input)
Low Boost : 0-10dB (40Hz)
Band : Low Pass Filter: 50-300Hz, -12dB/Oct
Noise Level : 65 dBA
Signal Circuitry : 6-70Hz Variable -12 dB/Octave Subsonic filter
Frequency Response : 10-300kHz (+/-0dB)
