ผู้เขียน หัวข้อ: Computer simulation analysis Quenchant performance _1055  (อ่าน 7067 ครั้ง)
ออฟไลน์ akingaway3
« เมื่อ: 16เม.ย.2013, 00:05:58 »
Computer simulation analysis of the performance of the hardening agent
Set the coordinate r at the remarkable San structure. Traditional m map, the amount of information to be classified as dynamic differential equations form model: J - 1uy-jkjyj (1 yJ) [:] (4), YJ (j = l,Gucci pas cher, 2 and 3): change products (the relative amount of iron chain, pearlite and bainite) {kj is ugly j, bj and c is the appropriate choice of parameters, they depend on the temperature, the grain is too small and the composition of the austenitic products. Ferrite, pearlite and bainite non-isothermal transformation, described by the solution of differential equations (4),cheap oakley sunglasses. For the growth of pre-eutectic iron chain body, formed the ferritic the most a lot of push drawn by 赫尔特格伦 grace (Hultsren,) equation. Estimate for the martensite volume of a new formula to replace the 克斯蒂内恩 (Koisti ~ en) and other well-known formula. 3 Results of the selection of six quenching Jing. The corresponding heat transfer coefficient as a function of surface temperature is given in Figure 1. For the quantitative characterization of the heat transfer coefficient,sac louis vuitton, we calculate the corresponding temperature TI and the most too hot transfer coefficient in the temperature range of 300.4 thousand ℃, 400 ~ 500 ℃, 500 ~ 600 ℃, 600 ~ 700 ℃ and 700 ~ 800 ° C, each is satisfied that the heat the average value of the transfer coefficient, H ·, HnH ·, and H,. These data are listed in Table 1. Heat transfer function from six pre-selected to proceed. Computer simulation,sac longchamp, we calculate the cooling and transition process. To this end, choose 10 ~ 50mm different diameter cylindrical specimens. The steel used in the simulations for ordinary carbon tangled steel and low-magic. Denoted by A and B, their components are listed in Table 2,longchamp pas cher. Assuming the initial trial Shan temperature T. For 860 ℃. Quantitative expression of the selected quenching Jing hardened performance, we calculated the relationship between the different diameter steel holding the horse and rod diameter is shown in Figure 2. The amount of the Golgi. Calculated the amount of martensite quenching the rod at the center of 40000ooo photo 20000 rumor the 10000 the built Ol00007500 scoundrel 50002500OO25050071; O temperature,nike free. The ℃ O2505007501000 temperature. Temperature ℃ O4, conclusions 2505007501000. The amount of martensite in the steel ° C temperature, ℃ temperature, ℃ prince Yu analysis of six selected quenching the Jing heat transfer coefficient and disheartened relations) in accordance with Figure 2, the cooling performance of the hardening agent can be used to meter temperature,oakley sunglasses outlet, ℃ calculated to characterize other words, the single parameter characterization of Zhangzhou a fire retardant properties. Another advantage of the proposed method: quenching capacity of the cooling medium may also be considering the steel composition and workpiece 6l · p. I Hill  ≥ The scoundrel mouth hopane} lotus p-.  ≥. Salar negligent meal of the day f poison} garlic p.  ≥. Excluded Pan millet} poison 'soil banner meal of the day} Adams Mino frog size estimate. The analysis of Figure 2, can be observed in the composition of the materials significantly affect the hardening of steel. Spit fire on the basis of the predicted martensite volume of six kinds of the study agent, on the order of the two steel is not the same. Can see that the order of actinium A, as follows,louis vuitton pas cher; w 30 wS1, o-A1, o-B1, o-L1 and P-L1} for steel B, the ranking is as follows; W 30,burberry pas cher, wsl, oAl O. L1 of o-Bl and P-L1 2) If you know the section size of the quenched steel grades and parts, the use of Figure 2 can help select the appropriate hardening agent. 3) are needed for further research to find out the composition of the steel and heat transfer coefficient varies with temperature changes in the microstructure distribution. 0l02030405O6O j2 · diameter, the mira table a different quenching agents, heat transfer characteristics I offend fire Jing almost all heat transfer coefficient Tt (Kw / m ° C) Code Type H3H4H5H6H7Cw 30 water 23.3] 88] 0.3 { . The 91,sac Gucci.3 {0'S1 water 675.13.62.31.22000 a B] {insect the 0 +51.71-50.50580 of o-Al sleeve 2.44.4.01.70. d5200 an L1 oil 1. ]]. 3]. 2O. 90. d475P-L1 aggregation rubidium 120.00.50. d0.2380 Table 2 studies the chemical composition of the two types of steel (set i) lC,} SJMPSCNiCu0.3060.570 0160.0] d0.10.150.10400.22O. 720. Ol90.010I_030.170.1 frog closure diameter, the relationship between the news of the film prince Yu calculated the amount of martensite in a variety of quenching medium and the diameter of rod (cylindrical specimens a central location) plus ∞ ∞ ∞ ∞ O, scorpionfish grapefruit
相关的主题文章:
   二辊周期式冷轧管机孔型与轧制力学算程序设计_3537
   Quench cooling technology status quo _1350
   Russia Chelyabinsk Steel Plant transformation cycl
